I am doing Indirect techniques since last month.
I do 2 to 5 cycles daily and use Differed Method
I am successful in Phantom wiggling, Rotation, Observing Images
Vibrations and sounds also occur sometimes.
I find myself lying in a different position at a different place.
Separation techniques feel some hard to apply.
I just want to Separate completely from the body and do next step: Deepening & Maintaining.
Re: Separation from the Physical body
Ghanshyam
- Michael Raduga
- Administrator
90% problems in the separation process come from psychology (blocks, fears, non confidence etc). Your case is the same.
When you feel any technique upon awakenings you are already in the phase.
Just try to understand this and separation will be much more easy
It means you are in the phase too.Astralbeing wrote: I find myself lying in a different position at a different place.
Ghanshyam
Thank You
Today using Deferred Method I attempted 5 to 7 times
and was able to separate partially -
at one time I felt my leg was moving and in 5 to 10 seconds it came back, the I realized that it was not my physical leg and
same happened with my hand and head
I just not realized or did not take immediate action
I will do it
I will do it
- Michael Raduga
- Administrator
Yes. it is another usual problem. You should act immediately when you feel something is hapeningAstralbeing wrote: I just not realized or did not take immediate action
- Michael Raduga
- Administrator
Just memorize these sensations and actions and it will be much more easy to do next time.
